EIGRP References
Nov 24th, 2009
what is a best references for EIGRP that explain EIGRP in more detail.
BR,
Auos.
Peter Paluch Tue, 11/24/2009 - 03:53
Also, if you are used to reading scientific papers, the following URL will lead you to an article from Dr. Garcia who authored the DUAL algorithm.
http://www.soe.ucsc.edu/research/ccrg/publications/jj.dual.ton93.pdf
The diffusing computations themselves have been coined by Dr. Dijkstra and Scholten and the paper discussing them can be found here:
http://www.cs.utexas.edu/users/EWD/ewd06xx/EWD687a.PDF
Both these documents are solid mathematical papers that discuss the underlying principles upon which the EIGRP is built.
Best regards,
Peter
