NAC 4.5 not performing ADSSO
rc.castillo
     I am running a NAC 4.5 platform on a network with 2 AD servers.  I have followed all the needed configuration and troubleshooting based on cisco documents, but ADSSO still doesn't work.  What am I possibly missing?  Time is synchronized running on a ntp server, have a valid ktpass, correct kerberos ticket shows on the kerbtray.  Still when my test pc logs on to the network, it is not performing SSO but asks for a local user account through the CCA.  Please help.  Thanks
Dan
Faisal Sehbai
Level 7
Level 7
Dan,
Please post your unauthenticated traffic policies.
Faisal
manfernandez
Make sure that it is not Windows Server 2008 64Bit (not supported)  also Windows Server 2008 32 or 64 bit require a patch.
If you login into the CAS with the /admin and turn the logging up to 'Trace' on 'Active Directory Communication Logging".  Look for an error:
Unable to start server ... Client not found in Kerberos database (6)
This means you need to install Hotfix KB951191
Also: if you run the ktpass on the same user multiple times, you will have issues as well (per TAC) you will need to create a new user and use that one.
