11-24-2009 01:31 AM
LMS 3.1,when i do a netconfig job for more than >5 devices, in the job tab the status is always showing as running. But when i do it for 2 or 3 devices as a batch it comes as successfull. Nevertheless the configurations are updated when more than 5 devices selected. We tried to reboot the server also. All the services are running in the common services>server>admin>processes tab.
Pls find enclosed the netconfigclient & jrm log files. We started the jobs around Tue Nov 17 07:00:03 hrs
Solved! Go to Solution.
11-24-2009 08:59 AM
Are you using SSH to connect to your devices? If so, then you are most likely seeing a known bug where SSH sessions can lock up either deploying a config, or fetching a config. All of the known SSH bugs are fixed in LMS 3.2, but patches for RME 4.2 are available from TAC. The bugs are CSCsv95235, CSCsx24218, and CSCsw88378.
11-25-2009 09:57 AM
Bug CSCsr93277 is only an annoying problem. It does not cause any functional loss. A patch is available from the TAC, or you can upgrade to LMS 3.2.
11-24-2009 08:59 AM
11-24-2009 10:26 PM
11-25-2009 09:57 AM
