pix 8.0 security context
roussillon
i want to have two security context for active/active failover. but I have a problem with the admin context
I want the context 1 to be empty and the context 2 to contient one gateway(on outside interface) and several vlans.
The context2 will be part of the failover group2 wich willbe active on security appliance2.
the context 1 will be part of the failover group1 wich will be active on security appliance1.
But wath do I do with the admin context? wath do I put or remove from this context? does it have to contains all the interfaces?
I have 802.1Q trunks for  both, outside & inside interfaces
I want  vlan2, vlan3, vlan4,vlan5 in the inside & vlan 10, vlan 11 in the outside
Security appliance1 would have:
context context1
  allocate-interface GigabitEthernet0.10 outside_context1
  allocate-interface GigabitEthernet1.2 vlan2
  allocate-interface GigabitEthernet1.3 vlan3
  config-url flash:/context1.cfg
context context2
  config-url flash:/context2.cfg
Security appliance2 would have:
context context1
context context2
   allocate-interface GigabitEthernet0.11 outside_context1
   allocate-interface GigabitEthernet1.4 vlan4
  allocate-interface GigabitEthernet1.5 vlan5
Wath about context admin wath do I out or wath doit remove?
Actually it has everithing:
context admin
  config-url flash:/admin.cfg
Thanks you very much
Jon Marshall
roussillon wrote:
context context1
context context2
context context1
context context2
context admin
The admin context is used purely for administering the ASA so it doesn't need to have all the interfaces in it. It should have it's own interfaces that ar used purely to remotely logon to the ASA and also for remotely accessing config files etc.
Jon
Jon Marshall
roussillon wrote:
context context1
context context2
context context1
context context2
context admin
Jon
yes it worked, Thank.
but  I can not make ping & traceroute work
I added
access-list outside_access_in extended permit icmp any any time-exceeded log disable
access-list outside_access_in extended permit icmp any any echo-reply log disable
access-group outside_access_in in interface outside
It works fine in single mode but it seems to have no effect in context mode
is there something missing?
