this configuration is currently locked for this VSAN ?
Nov 24th, 2009
hello
trying to modify interop mode received this error message
what does it mean ?
do i need to shutdown vsan first ?
thanks for any advice or pointer
JYP
Michael Brown Mon, 11/30/2009 - 13:38
I don't think you need to suspend a VSAN to change the interop mode.  You can issue this command to see if CFS (Cisco Fabric Services) has any application locked for that vsan 'show cfs lock'.  If you see any application that has the swtich locked, you can issue the command 'xxx abort' while in configuration mode where xxx is the application that currently has the CFS lock.
Hope this helps,
Mike
Trending Topics: Storage Networking
