Embedded syslog manager and TCL scripting
Nov 24th, 2009
I'm a newbie to TCL scripting and I'm doing some tests with ESM and TCL scripts
The final idea is  to implement a script that will send an email when an EIGRP neighbor changes takes place. For the moment I'm just beginning and I already have an issue
I tried to implement the following:
if { [string length $::orig_msg] < 5 } { puts "test2" } else { puts "bigger then  0" }
As soon as I come out of configuration mode it should put the text " bigger then 0."
When I just implement
if { [string length $::orig_msg] > 5 } { puts "test2" }
I get the output "test2"
As soon as I add the else statement  it doesn't do anything anymore. I suspect that there is a syntax error  but I can't find it
Can anybody help me ?
gr
wim
Joe Clarke Tue, 11/24/2009 - 08:55
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There is no Tcl syntax error per se, but using puts with ESM can be unpredictable.  Try using return instead to return a new syslog message:
     return "test2"
} else {
     return "bigger than 0"
