SPA-2102 fax rate 4800
Nov 24th, 2009
  Most our clients have SPA 2102 boxes and we are using T38 protocol for faxing. Everything is OK, when faxing with speed 9600 , but the problem appears if another side supports only 4800 speed. For example, one my client wants send fax to B number. B side is connected over radio and supports 4800 fax speed for incoming and 9600 for outgoing. So what should I do? My SPA-2102 version is:
Software version: 5.2.10
Hardware version: 1.3.5(a)
  Maybe somebody can advice which software version should I use to support 4800 speed?
Thanks for help
Alberto Montilla Tue, 11/24/2009 - 06:17
Dear Sir;
Please note 4800 speed is not supported (lowest speed supported is 7200 bps).
Related Content
