Translation Patterns
Nov 24th, 2009
Hi All,
I've some troubles to configure a translation pattern as requested by the customer. In fact, we are migrating a customer to the Cisco IPT infrastructure. For the moment, they use a Nortel CS PBX - great
Well in the Nortel world, they have a feature called SYSPEED... You push on a button, you enter a code and a number will be called.
This is easy to configure by using for instance translation patterns. Now the complicated part, sometimes they have codes which refers to a root number. The user has to complete the code with the right extension of the person who he has to call.
Well to be more technical:
User A wants to call user B (who is on another site - so external call) - the code is *0001437 so it will call 0254825 (root) prepend with 437, so finally 0254825437. This is not so complicated to put in place!
Translation Pattern: *0001.XXX
Discard digits: PreDot
Called Party Transform Mask: XXX
Prefix: 0254825
My question to you! How can I prepend n digits without knowing the length... Like *0001.! (for the translation) and something like ! in the called party transform mask.
Martin Schoonbroodt
Dimension Data Luxembourg
Jonathan Schulenberg Tue, 11/24/2009 - 12:58
  • Cisco Designated VIP,
    2017 IP Telephony
You can leave the Called Party Transformation Mask field blank and it will keep all remaining digits not removed by DDI.
To continue your example:
Translation Pattern: *0001.!
Prefix: 0254825
martin.schoonbroodt Wed, 11/25/2009 - 01:25
Thanks for the information.
I tested it and it seems to match with my requirements.
Adi :-)
Related Content
