Todd Pula Tue, 11/24/2009 - 08:47
As of now, the AnyConnect SSL VPN client is the only 64bit compatible client.
VPNHaus_SF_2 Wed, 11/25/2009 - 06:24
Hi Andrei,
A 64 bit VPN client you can look in to is the NCP Secure Entry Client-- its IPsec and compatible with Vista and Windows 7.  As Topula mentioned, Cisco is currently offering the AnyConnect as a 64 bit VPN client, however its SSL.  Depends on what you are looking for..
Good luck!
-VPN Haus
http://vpnhaus.wordpress.com/
Phillip Remaker Fri, 02/19/2010 - 11:13
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
Matthew Guerrera Wed, 11/10/2010 - 06:14
Hi Phillip,
Is this still the case? I followed the link providied and it just leads me to a standard download of 5.0.07.0410 32-bit only.
Matt
mbilgrav Wed, 11/10/2010 - 06:38
Yo,
From the release notes :
These release notes are for the Cisco VPN Client, Release 5.0.07.0290. The names of the files on the
software download site are:
• vpnclient-win-msi-5.0.07.0290-k9.exe for Windows on x86 (32-bit).
• vpnclient-winx64-msi-5.0.07.0290-k9.exe for Windows on x64 (64-bit).
New Features
VPN Client 5.0.07 features the following:
• Support for Windows 7 on x64 (64-bit). This release, however, does not support WWAN devices
(also called wireless data cards) on Windows 7 x86 (32-bit) and x64.
• Support for Windows Vista on x64.
• Packet LZS compression for x64 VPN Client.
Note that this version does not provide online help.
System Requirements
VPN Client 5.0.07 supports the following Microsoft OSs:
• Windows 7 on x64 (64-bit)
• Windows 7 on x86 (32-bit) only
• Windows Vista on both x86 (32-bit) and x64
• Windows XP on x86
Say no more !
Matthew Guerrera Wed, 11/10/2010 - 06:40
shame on me!
I should not have assumed the latest release would have the same compatibility as the previous release...
Thanks!
Matt
Phillip Remaker Wed, 11/10/2010 - 10:04
Do you mean "should have assumed?"
The latest release does indeed support 64-bit Windows Vista and Windows 7.
Phillip Remaker Wed, 11/10/2010 - 10:14
OK, looking again at http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 at this time, when you select the latest version (5.0.07.410 as of this writing) you will see a link on the page that says "Please check here for latest 64-bit client."  That will lead you to the 64-bit client.
For whatever reason, 5.0.07.290 is the latest version of 64-bit VPN client.  If you select that you can get a 64-bit download.
It is not clear to me if/when 5.0.07.410 will be released as 64-bit.
Todd Pula Wed, 11/10/2010 - 10:49
The 5.0.07.410 client included a GINA fix which was relevant to 32-bit OS only.  The /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} 5.0.07.290 client is the latest available for 64-bit.
