ACNS 4.1.1
Nov 24th, 2009
I have an CE507 with software version 4.1.1 , I need to upgrade it to ACNS-5.5.11.2-K9 , but before I think it should be upgraded to 4.2.1 and then to 5.x  the problem is I am unable to find 4.2.1 or later anywhere , I just have ACNS-5.5.11.2-K9 . I will appreciate if anyone can help me find 4.2.1 and later
rvavale Tue, 11/24/2009 - 17:43
  • Cisco Employee,
Hi Farshid,
Myself I have never upgraded CE from  ACNS 4.x to 5.x.
However I found below link which explains migrating options from ACNS 4.x to ACNS 5.x,
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/acns/maintenance/v5x/upgrade/guide/6695migr.html#wp1041490
Link to  download ACNS Software 4.x images can be found at this url,
http://www.cisco.com/cgi-bin/tablebuild.pl/uce42
Just to let you know CE-507 is EOL and its also End of support as of July 6 2009
Hope this helps,
Best Regards,
Rahul Vavale
farshid.sheikhi Fri, 11/27/2009 - 22:08
Hi Rahul
First thanks for the answer , second unfortunately I have not a cisco account to download the software , I will ask from my friend who recently takes his CCIE  to know if he can download it or not , anyway thanks again.
Farshid
