Application invocation from an UCCX script
Nov 24th, 2009
Hi folks,
Do you know if it's possible to invoke an application in the UCCX server from an script?
The application I need to invoke is a .class file and I have tried to use java code in one step with the Runtime class but it isn't interpreted by the editor.
I have deployed a custom class that I cannot also to invoke due to the manipulation of a String that the JRE can do but not the editor.
My idea then was to execute it throw the server and to store the result of the record on a file and after open that file and interpret the result.
Any idea?
Thanks a lot.
