CSS 11506 max window size
Gilles Dufour Tue, 11/24/2009 - 08:53
For SSL traffic terminated on the CSS, you can use the following command
CSS11503-2(config-ssl-proxy-list[gdufour])# ssl-server 1 tcp virtual ?
  ack-delay           Specify the client-side SSL TCP delayed ack timeout
                      (milliseconds)
  inactivity-timeout  Specify the client-side SSL TCP inactivity timeout
                      (seconds)
  nagle               Specify the client-side SSL TCP Nagle Algorithm State
  retrans             Specify the client-side SSL TCP min retransmission timer
                      (milliseconds)
  syn-timeout         Specify the client-side SSL TCP syn timeout (seconds)
  window              Specify the client-side SSL TCP advertised window size
                      (bytes)
For ther type of traffic, I do not think there is a way to control the window size.
Gilles.
