RV082 VLAN's - How can I find out which clients are on them?
Answered Question
We have an RV082 router and two of the ports are designated as VLAN2 and VLAN3, the router interface only gives a status report of the port but I can't find anyway to see which computer's are on those VLAN's. Is there anyway to do this? Thank you.
Correct Answer by David Carr about 7 years 3 months ago
Unfortunately there is no other monitoring tools on the router.  You can view the port status and see the vlans there.  But other than that you will not be able to.  You might could find a network tool that will help you identify your network and monitor it.
Overall Rating: 5 (1 ratings)
David Carr Tue, 11/24/2009 - 07:31
The only way to see clients connected in the router is through the DHCP clients table.  If they don't get their address dynamically there is no way to view it through the router.
The router is DHCP, I can see everybody that way but what I was wondering because that information isn't on the DHCP status window is who is on let's say, we have 3 VLANS setup in the router, the router tells me through System Summary Port Stats which port is set to which VLAN but I do not see anywhere in the router interface which IP addresses are going to VLAN1, VLAN2 or VLAN3 for instance. It does not show this in the Port Management screen either. Was wondering if there is some way to see this in CMD? I do not know how to interface with the 3 switches we have in CMD either. I am just an old A+ guy in a small company who knows how to fix computers but don't know much about networking. I was put into this position because I could change out a video card so they thought I was the guy to run the network because they can't afford to do much more than that with the economy in a shambles. Thanks for any help you can give me.
Dean
P.S. I'm really a drafter.
Correct Answer
David Carr Tue, 11/24/2009 - 08:14
