Big Exchange priv1.edb
Answered Question
Guys:
I am using Cisco Unity 4.x. Is there anyway of decreasing the Exchange priv1.edb database file size?
Should the database file decrease with a proper backup with and Exchange Agent?
Thanks, Tom
Correct Answer by Brandon Buffin about 7 years 6 months ago
You can determine the approximate amount of space that will be recovered by the offline defrag by looking at the event viewer events from the nightly online defrag. Take a look at the following MIcrosoft KB article.
http://support.microsoft.com/?kbid=195914
Hope this helps.
Brandon
Correct Answer by Jaime Valencia about 7 years 6 months ago
I really cannot tell you if the exchange backup has something to do with that.
It will recover space, but i cannot tell you how much
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Tue, 11/24/2009 - 10:36
  • Cisco Employee,
  • Hall of Fame,
    2011
java
Correct Answer
Brandon Buffin Tue, 11/24/2009 - 10:48
  • Purple, 4500 points or more
Hope this helps.
Brandon
