Ipv4 to Ipv6
Answered Question
Nov 24th, 2009
I have a cisco router 2800 as my default gateway in my LAN. IPv4 is  the format of the addesing in the LAN and the WAN interface. But now, the WAN conectivity will be IPv6.
The actual diagram is the folowing:
LAN: 172.16.30.X/23 ---ipv4-LAN--> f0/0(Router)f0/1---ipv4-WAN-->
The router 2800 has a defaul router: 0.0.0.0 0.0.0.0 f0/1
The diagram will be:
LAN: 172.16.30.X/23 ---ipv4-LAN--> f0/0(Router)f0/1---IPV6-WAN-->
How enable the ipv6 routing in the 2800 Routers?
What I need?
Correct Answer by Jerry Ye about 7 years 2 months ago
You will need to check your 2800's software to see if the following command is available
ipv6 unicast-routing
This will turn on IPv6 routing, and you can assign IPv6 address and configure IPv6 default route on your router.
You also need IPv4 to IPv6 NAT to be configured.
Please see the following link on how to configure IPv6 in IOS 12.4
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/12_4/ipv6_12_4_book.html
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Tue, 11/24/2009 - 12:37
jerry
ricardorojas123 Tue, 11/24/2009 - 12:46
Yes, the command is supoorted in the Cisco Roter 2800.
My configuration is the following:
ip dhcp excluded-address 172.16.30.1 172.16.30.10
ip dhcp pool lan
   network 172.16.30.0 255.255.255.0
   default-router 172.16.30.1
interface FastEthernet0/0
description ***LAN***
ip address 172.16.30.1 255.255.255.0
ip nat inside
interface FastEthernet0/1
description ***WAN***
ip address 200.111.X.X 255.255.X.x
ip nat outside
access-list 1 permit 172.16.30.0 0.0.0.255
ip nat inside source list 1 pool ranca overload
