i am configuring a policy on the Cisco clean access , & i need to know if cisco nac can check the following points :
1- CD ROM, floppy Disk to be check if it is disabled or enabled. if enabled prevent the access
2- Check for USB devices connected to USB ports (except : printers,keyboard and Mouse ) , else should prevent access
3- check for disable the wireless connection adapter , if enabled prevent access
