DID - outgoing translation rule
Nov 24th, 2009
guys,
how would you implement outgoing rule that will show up your DID number when you are calling from inside?
my DID list isn't in order, but the ISP is sending 4 digits and inside extension is 3. i have done the translation for incoming, but for outgoing call is still showing up as the main number.
example:
DID = 212 456 7890 to ext 801. so when 801 makes a call, it will show up as 212 456 7890 instead of 212 456 1111.
thank you.
Steven Smith Tue, 12/01/2009 - 14:14
  • Gold, 750 points or more
I am using CCA 2.2...
If you go to Configure -> Telephony -> Dial Plan -> Outgoing, then look at the Caller ID tab, you should be able to add your outgoing caller ID in there.
