11-24-2009 05:26 PM - edited 03-04-2019 06:47 AM
now,on the cisco 7606 router ,only few traffic's tos,not like cisco 7507, by show ip cache verbose flow,can see all the traffic's tos.
how command can see all traffic's tos on cisco 7606.
76WA01-A1#sh ip cache verbose flow
MSFC:
IP packet size distribution (3202688 total packets):
1-32 64 96 128 160 192 224 256 288 320 352 384 416 448 480
.000 .383 .023 .091 .076 .024 .000 .006 .003 .000 .000 .000 .000 .000 .000
512 544 576 1024 1536 2048 2560 3072 3584 4096 4608
.000 .000 .000 .318 .047 .000 .000 .000 .000 .000 .024
IP Flow Switching Cache, 278544 bytes
8 active, 4088 inactive, 379552 added
9844511 ager polls, 0 flow alloc failures
Active flows timeout in 1 minutes
Inactive flows timeout in 15 seconds
IP Sub Flow Cache, 33992 bytes
8 active, 1016 inactive, 371703 added, 371703 added to flow
0 alloc failures, 0 force free
1 chunk, 1 chunk added
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
TCP-Telnet 864 0.0 133 40 0.0 22.2 10.6
TCP-FTP 3 0.0 1 104 0.0 0.0 15.7
TCP-FTPD 3 0.0 1 44 0.0 0.0 6.2
TCP-WWW 17 0.0 2 139 0.0 0.7 15.4
TCP-SMTP 1 0.0 1 40 0.0 0.0 15.5
TCP-X 2 0.0 1 44 0.0 0.0 15.5
TCP-other 19435 0.0 1 45 0.0 2.9 14.3
UDP-NTP 29 0.0 1 76 0.0 0.0 15.5
UDP-other 210938 0.1 1 113 0.2 0.7 15.4
ICMP 22916 0.0 68 1040 0.9 13.3 13.0
IP-other 125336 0.0 9 75 0.7 34.2 7.8
Total: 379544 0.2 8 549 2.0 12.7 12.7
SrcIf SrcIPaddress DstIf DstIPaddress Pr TOS Flgs Pkts
Port Msk AS Port Msk AS NextHop B/Pk Active
AT1/1/0.1 80.15.20.97 Local 8.15.20.98 01 00 10 5
0000 /30 0 0800 /30 0 0.0.0.0 100 0.1
Fa1/0/1 12.143.4.70 Null 224.0.0.10 58 C0 10 5
0000 /30 0 0000 /0 0 0.0.0.0 60 18.5
Fa1/0/0 12.143.4.66 Null 224.0.0.10 58 C0 10 11
0000 /30 0 0000 /0 0 0.0.0.0 60 47.0
Fa1/0/1 12.11.12.118 Null 19.251.12.1 2E 90 10 1
0000 /24 0 0000 /0 0 0.0.0.0 160 0.0
Fa1/0/0 12.135.31.212 Local 12.143.3.200 11 00 10 1
B13C /8 0 00A1 /32 0 0.0.0.0 102 0.0
Fa1/0/1 12.136.14.251 Local 12.143.3.200 06 00 18 21
DA02 /8 0 0017 /32 0 0.0.0.0 40 4.2
AT1/1/0.1 8.15.20.97 Null 224.0.0.10 58 C0 10 4
0000 /30 0 0000 /0 0 0.0.0.0 60 13.8
Fa1/0/1 12.129.115.222 Local 12.143.3.200 01 00 10 9
0000 /8 0 0800 /32 0 0.0.0.0 84 8.0
Solved! Go to Solution.
11-25-2009 08:51 PM
11-25-2009 08:51 PM
Try 'show mls ip detail'
Edison
11-25-2009 10:08 PM
thx. can use show mls netflow ip qos or show mls netflow ip detail.
