11-24-2009 10:28 PM - edited 03-06-2019 08:43 AM
Can anyone please advise if the 4500 SUPV with WS-X4306-GB support variable speeds of 100/1GigE.
I checked our 4500 using the speed command and it does not give you the option.
Just wanted to double check.
Appreciate feedback.
Solved! Go to Solution.
11-25-2009 02:20 AM
billsayegh wrote:
Bill
If you mean does the WS-X4306-GB support variable speeds then as far as i know it doesn't. It only support gbps speeds.
Jon
11-25-2009 02:20 AM
billsayegh wrote:
Bill
Jon
11-25-2009 01:04 PM
Jon
Many thanks for the response.
Bill
