Easy VPN server on Cisco 857 not working for remote desktop client
Nov 24th, 2009
Hi All,
Long time reader, first time poster here.  I have configured a Cisco 857 for internet access and as a remote Easy VPN Server.  The internet portion works fine, however I am having difficulty getting my Easy VPN Remote desktop client to connect propperly.
The remote client can authenticate and connect without difficulty.  It is issued an ip from the address pool that I have specified.  However, ping only works on a hap-hazard basis and when I do get a reply, the reply is from the outside interface, not from the ip address I specified.  An ipconfig on the remote PC shows that I have been issued an IP address from the VPN Pool, but no default gateway.  tracert shows that the next hop router is the interface of the Cisco 857 router acting as an Easy VPN server.  But if I tracert another internal IP address, it is simply lost with nowhere to go.
I have gone through countless examples and troubleshooting.  However there is something here that I am just missing.
I want my remote desktop pc, to become part of the inside network.
Points to note:
Internal IP address subnet 192.168.1.0 / 24
Default-router                    192.168.1.253
VPN Pool subnet              192.168.99.10 to 192.168.99.20
Configuration shown below and attached.
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ****Sydney
boot-start-marker
boot-end-marker
logging buffered 16000
no logging console
enable secret 5 *****
aaa new-model
aaa authentication login ezvpnauth local
aaa authorization network ezvpnnetwork local
aaa session-id common
clock timezone cst 10
clock summer-time cdt recurring
crypto pki trustpoint TP-self-signed-3889388268
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3889388268
revocation-check none
rsakeypair TP-self-signed-3889388268
crypto pki certificate chain TP-self-signed-3889388268
certificate self-signed 01
  3082025A 308201C3 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33383839 33383832 3638301E 170D3032 30333031 30303139
  33355A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 38383933
  38383236 3830819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  810097D7 8B3DB947 C303E99F 0488EDCF A1C309EC BC899416 B6F0ACFB EF333A1C
  7E6DDBBB F7FC2F62 50A28EC8 8AF0990F 3153F868 9F3E45B7 85291FDA 593E4F44
  6C1C0740 08847090 9ED7EC04 2E08307C 149088AD 58EE21AD F3C14728 46F4772D
  A9545A3A 582DAEBA EB60EDA7 1AB05EFE C8D34759 4A442C1D 29BFBC00 53778D86
  772D0203 010001A3 8181307F 300F0603 551D1301 01FF0405 30030101 FF302C06
  03551D11 04253023 82214869 746F7271 75655379 646E6579 2E646972 6563742E
  74656C73 7472612E 6E657430 1F060355 1D230418 30168014 D3C9F440 91F5B2B1
  94422CC6 218578CD 6B0733EC 301D0603 551D0E04 160414D3 C9F44091 F5B2B194
  422CC621 8578CD6B 0733EC30 0D06092A 864886F7 0D010104 05000381 81008D66
  EA3B530A 852A5227 1BF23893 6DE80182 D3C615C6 9CA46F3A CE5B49A1 4B157DC9
  13547593 AE978AF3 13959457 7FE27305 C2EAC2EC 782FD287 FA797C37 16DA63F3
  47439441 3BF89EFA 72D055A0 70CB7211 13440993 A6F5D3F0 41F1B08D AF53E380
  10D0A0EE BD9CC865 42B05AF8 85B76313 CB79FD9A 27F8ECBD 9B22FEE3 E468
        quit
dot11 syslog
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.253
ip dhcp pool CUSTOMER_LAN_POOL
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.253
   dns-server 203.50.2.71 139.130.4.4
ip cef
no ip bootp server
ip domain name direct.telstra.net
ip name-server 203.50.2.71
ip name-server 139.130.4.4
username admin privilege 15 secret 5 ****
username chris privilege 15 password ****
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp xauth timeout 60
crypto isakmp client configuration group EZVPNgroup
key cisco123
pool ezvpnpool
acl SPLIT_TUNNEL
max-logins 5
netmask 255.255.255.0
crypto ipsec transform-set ezvpn_transform esp-3des esp-sha-hmac
crypto dynamic-map ezvpn-dymap 1
set transform-set ezvpn_transform
reverse-route
crypto map MYCMAP client authentication list ezvpnauth
crypto map MYCMAP isakmp authorization list ezvpnnetwork
crypto map MYCMAP client configuration address respond
crypto map MYCMAP 65535 ipsec-isakmp dynamic ezvpn-dymap
archive
log config
  hidekeys
ip ssh version 2
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
load-interval 30
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
spanning-tree portfast
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Vlan1
description CUSTOMER_LOCAL_LAN
ip address 192.168.1.253 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan2
no ip address
interface Dialer0
description ADSL Link FNN N****R
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password 7 ****
crypto map MYCMAP
ip local pool ezvpnpool 192.168.99.10 192.168.99.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
ip http access-class 22
ip http authentication local
ip http secure-server
ip nat inside source list 22 interface Dialer0 overload
ip access-list extended SPLIT_TUNNEL
permit ip 192.168.1.0 0.0.0.255 any
permit ip 192.168.99.0 0.0.0.255 any
access-list 22 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
banner login ^C
* Access to this computer system is limited to authorised users only. *
* Unauthorised users may be subject to prosecution under the Crimes   *
*                       Act or State legislation                      *
* Please note, ALL CUSTOMER DETAILS are confidential and must         *
*                         not be disclosed.                           *
^C
line con 0
no modem enable
transport output all
line aux 0
line vty 0 2
access-class 22 in
exec-timeout 20 0
transport input telnet
line vty 3 4
access-class 22 in
exec-timeout 20 0
transport input ssh
scheduler max-task-time 5000
end
****Sydney#
Related Content
