Device Mobility
Answered Question
Nov 25th, 2009
Hi All,
We are running CUCM 6.X in a cluster environment. There's one publisher and few subscribers in this cluster and phones on the respective locations register with the respective subscribers which are sitting on those locations.
I configured device mobility. When a phone moves from one location to another, on the display it says the device is in a roaming location but it does not change the device pools and register with the local subscriber. It registers with the previous subscriber.
I want to know whether when a device moves from one place to another is there a possibility of registering that device on the local subscriber of that location without manually changing the device pool of that phone to the local device pool.
Thanks.
Correct Answer by KonradStepniewski about 7 years 5 months ago
DP is the only way to give phone information about CMs I'm afraid.
Device mobility don't change Cisco Unified Communications Manager Group where is CM information provided.
DM will use some settings from dial pool:
Roaming Sensitive Settings
The parameters under these settings will override the device-level settings when the device is roaming within or outside a Device Mobility Group. The parameters included in these settings are:
Date/time Group
Region
Media Resource Group List
Location
Network Locale
SRST Reference
Physical Location
Device Mobility Related Settings
The parameters under these settings will override the device-level settings only when the device is roaming within a Device Mobility Group. The parameters included in these settings are:
Device Mobility Calling Search Space
AAR Calling Search Space
AAR Group
More info you can find: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/6x/devmobil.html
rate if this help
Overall Rating: 5 (2 ratings)
Correct Answer
KonradStepniewski Wed, 11/25/2009 - 03:50
  • Silver, 250 points or more
Date/time Group
Region
Location
Network Locale
SRST Reference
Physical Location
AAR Group
rate if this help
dialogcco Wed, 11/25/2009 - 22:59
Thank you for the reply.
Is there any other method to do this without manually changing the device pool?
Correct Answer
KonradStepniewski Thu, 11/26/2009 - 00:01
