11-25-2009 02:51 AM - edited 02-21-2020 10:24 AM
I added external authentication for NAC through AD by ldap." authentication against backend Ative Directory"
I followed the procedure as per documentation but agents cant login now. CAS version is 4.1.3 and CCA doest show provider other then local database.
Authentication error" CCA cant establish secure connection to CCM at A.B.C.D"
Any suggetions.??
Thanks in advance.
11-26-2009 12:05 PM
Make sure that the LDAP provider you defined is visible to the users within the login pages. If it's not checked-marked there, it won't show up as an option.
HTH,
Faisal
12-03-2009 09:54 AM
Hi Faisal,
Thanks for your reply. Still i have problems with CCA. pls see attached for agent error.Both local database and AD users are not authenticating.
any suggestions..
12-03-2009 09:56 AM
12-07-2009 06:48 PM
Please post your login pages setup.
Faisal
