ICM Service Release.
You should have them all the same. In a trivial little system like you have, there is no reason not to.
Customers who have large systems with many tens of PGs face a more difficult time when applying SRs or upgrading than you do, and ICM does allow the PGs to lag the version on the central controller, but this is just a temporary state.
ICM engineers endeavour to have the same version and SR on all nodes. ES are slightly different and should only be installed on the node they address.
Geoff
david.macias Sat, 11/28/2009 - 20:55
  • Blue, 1500 points or more
One more thing, the SR notes should state what components need to be upgraded.  Also note that this will more than likely cause a brief service outage.
david
