CCM Upgrade
Nov 25th, 2009
I want to upgrade CCM 6.1.3 to CCM 7.1.3 but I don't know the exact part number for it. Does anybody know this? Is there any other thing needed for this upgrade. I need clarifications
Overall Rating: 5 (1 ratings)
Chris Deren Wed, 11/25/2009 - 13:22
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Assuming you have valid UCSS support contract you can do this via PUT tool www.cisco.com/go/upgrade and request the upgrade media there.
HTH,
Chris
Sushil Kumar Katre Thu, 11/26/2009 - 20:24
  • Gold, 750 points or more
As Chris stated if you have UCSS you order the upgrade through PUT at no additional cost.
However if your CUCM is not covered under UCSS then you'll have to pay for the upgrade.
The Part Numbers depends on the MCS server model you have. If you have 7835 for example the part nnumbr will be -
CM7.1-U-K9-7835= SW Upgrade to CM 7.1 - 7835
-> Sushil
vivkalra Thu, 11/26/2009 - 21:48
If you are not able to order the upgrade through the PUT tool
<http://www.cisco.com/upgrade>
You can You can contact Customer Service through 1 of the following ways.
PHONE : 1-800-553-6387
Email : [email protected] , subject line put in "Missing CD/DVD Request".
Customer service will need as much of the following information you can provide.
1. Reason for Request
2. SO#
3. SAS/SASU (or any other Software Contract #)
Vivek
