Which MPEG4 - Part2 format that DMP 4305G support?
Answered Question
Nov 25th, 2009
Dear All,
I would like to know which MPEG4 - Part2 format that DMP 4305G support? Since I tried every codec
example.
     Standard MPEG4
     DivX
     Xvid
Can anyone help me or give me example file format so that I can get more information to convert file to play in DMP 4305G.
* I'm using DMP version 5.1
Thank you in advance
Correct Answer by Charles Little about 7 years 1 month ago
see below
Overall Rating: 5 (1 ratings)
Charles Little Thu, 12/10/2009 - 13:19
The only h.264 the DMP 4305 will support is MPEG 4 part 2 - Advanced Simple Profile (mp4v) @ Level 5. The file extension is *.mov.
The DMP 4400 will support MPEG 4 part 10 - (h.264) @ Level 5 which is a *.mp4 file extension. or MPEG-2 -TS/h.264 with a *.mpg extension.Supported Bit rate up to 15 Mbit/sec recommended
for HD: 12 Mbit/sec - 15 Mbit/sec
for SD: 5 Mbit/sec - 8 Mbit/sec
On both DMPs is supported a MPEG-2 Transport Stream at 720p for the full screen, and NTSС DV or PAL DV
I hope this helps.
Cheers
C.O. Little
Related Content
