Netconfig job on the interface level
Answered Question
Nov 25th, 2009
I am trying to create a netconfig job to remove ip helpers from my vlan interfaces.  Is this possible?  How can this be accomplished?  Thank you for your input.
Correct Answer by Joe Clarke about 7 years 3 months ago
This might be better accomplished with a baseline compliance template instead of a Netconfig job.  Create a new advanced baseline template with the following configuration:
Submode: interface [#Vlan.*#]
Body:
- ip helper-address [HELPER]
That should remove all ip helper-address entries from all Vlan interfaces.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Wed, 11/25/2009 - 10:09
Body:
pmpesha Wed, 11/25/2009 - 12:32
Thank you very much Jclarke for your prompt respond.   Works great!
