HTTP Status 500 - Internal Server Error
Answered Question
Nov 25th, 2009
When I go to Device Update, ant try to have a look at RME packages, I got this error, only for
RME.
CW LMS 2.6 over W2003.
Correct Answer by Joe Clarke about 7 years 3 months ago
No, that procedure will not work for you.  Your problem is due to corrupt package maps most likely brought on by CSCsj58812.  See the Release-note in the bug for the workaround procedure.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 11/25/2009 - 10:10
Post the NMSROOT/lib/classpath/com/cisco/nm/xms/psu/conf/tag.properties, NMSROOT/www/classpath/com/cisco/nm/xms/psu/maps/rmePackageMap.map and rmeDeviceMap.map files.
mserranocisco Thu, 11/26/2009 - 00:05
Hi!
here you have...
I've found this procedure, but not tried:
1. Stop CiscoWorks daemon manager: net stop crmdmgtd
2. Go to \CSCOpx\MDC\Apache\conf\SSL and delete all the server.*
files.
3. Go to \CSCOpx\MDC\Apache folder and type: perl configssl.pl
-enable
4. Fill out the form again with all the requested information.
5. If you do not use SSL to access CiscoWorks type: perl configssl.pl -
disable
6. Restart CiscoWorks daemon manager: net start crmdmgtd
7. Wait about 15 minutes or so and login again.
Correct Answer
Joe Clarke Thu, 11/26/2009 - 00:14
mserranocisco Thu, 11/26/2009 - 01:55
C:\Documents and Settings\Administrador>set NMSROOT=%CWMIBDIR%\..\..\..
C:\Documents and Settings\Administrador>%NMSROOT%\lib\jre\bin\java -classpath %N
MSROOT%\lib\jre\lib;%NMSROOT%\lib\classpath;%NMSROOT%\objects\log4j\1.1.3\log4j.
jar;%NMSROOT%\MDC\tomcat\shared\lib\MICE.jar;%NMSROOT%\MDC\tomcat\shared\lib\NAT
IVE.jar;%NMSROOT%\MDC\tomcat\shared\lib\jdom.jar;%NMSROOT%\www\classpath;%NMSROO
T%\lib\classpath\servlet.jar;%NMSROOT%\MDC\tomcat\webapps\cwhp\WEB-INF\classes c
om.cisco.nm.xms.psu.packagemgmt.map.CreateMaps %NMSROOT%\www\classpath\com\cisco
\nm\xms\psu\pkgs\rme
log4j:ERROR No appenders could be found for category (com.cisco.nm.xms.psu.util.
PackageUtils).
log4j:ERROR Please initialize the log4j system properly.
\nm\xms\psu\pkgs\cvw
PackageUtils).
mserranocisco Thu, 11/26/2009 - 02:26
I just wanted to add that CV is working fine, we only got the error for RME.
mserranocisco Thu, 11/26/2009 - 02:57
Hi Joe,
after deleting rme file and running command again, it works!
Thanks again.
