Reset guest user password from WCS
Nov 25th, 2009
I have setup a guest account on WCS and want to reset the password once a week, is it possible? There is a checkbox: Generate new password on every schedule, but looks like deafult is everyday and there is no option to change it.
I want to setup a guest account through WCS and reset password once a week.
Thanks a lot in advance!
Lucien Avramov Fri, 11/27/2009 - 18:24
Generate new password on every schedule = daily
You are correct, this would be an enhancement request for WCS.
Depending on how many guest users you have you could manually regenerate the passwords or use the only option available for now.
Forrestermu_2 Tue, 12/01/2009 - 08:14
Thanks, is it a way to reset local net user's password once a week on WCS? We want to automat this process as we have more than 20 sites.
Lucien Avramov Tue, 12/01/2009 - 22:52
Integrate WCS with ACS and have this policy in place on the ACS, that is the best way to scale this.
No way to do it ''automatically'' on the local WCS users.
Trending Topics - Security & Network
