Question : MWI not working but can retreive voicemail on phone
Nov 25th, 2009
Hi guys
I am installing Unity 5.0 with Failover. I can leave a voicemail but the MWI does not come on but I can retreive voice messages.
Any suggestions on the cause and how to resolve it?
Thanks in advance
Jonathan Schulenberg Wed, 11/25/2009 - 10:15
  • Cisco Designated VIP,
    2017 IP Telephony
Check to make sure that the MWI numbers are in the CSS of the VM ports.
Bradford Magnani Wed, 11/25/2009 - 10:25
  • Cisco Employee,
You also can open the Port Status Monitor in Integration Tools in the Tools Depot and make sure that the MWI is actually being dialed out.  You can accomplish this by selecting Settings>Real Time View in Port Status Monitor.
Hope that helps,
Brad
okoye.stephen Wed, 11/25/2009 - 11:31
Thanks guys,
I have checked, the MWI is in the same CSS with the VM ports.
Brad, will try what you said.
Thanks again
