MPE V2.1.1.2 Memory usage
Nov 25th, 2009
I have MPE V running on a cisco MCS server and the memory usage sits at about 99%, with no meetings in progress, is this normal?
Ginger Dillon Mon, 11/30/2009 - 13:59
Hi -
If your MPE server is performing reliably, i.e. when you have meetings in progress, and you don't observer performance degradation then it may be just the Linux OS doing its thing -  However, even Linux OS can have memory leaks at times.  If you reboot the MPE server, does the memory go down to a lower level of consumption?  Growing increase in memory consumption over time could be a memory leak - I checked for MPE version 2.1 release Open Caveats and did find a hit, but would recommend you check with TAC on its appropriateness for your observations -
Hope this helps!  Ginger
