upgrade CUCM 5.1.3 to 7.1.x with Remote source
I have to upgrade from CCM 5.1.3 to 7.1.X. For some reason the CD-Rom drive is unable to mount the DVD.
Then, I have to do from an upgrade from using a Remote Source  FTP/SFTP.
However for the verison 7.X, there are several files involved in the Upgrade. Do the CallManager dowload all the files .a .b .c and .sgn automatically, or, in this case the only way to make the upgrade to 7.1.x is only using LOCAL SOURCE method ( CD/DVD).
Actually, I didn't yet tried the remote source method, but , I'm just triying to find answers before doing any operation.
many thanks.
vivkalra Sat, 11/28/2009 - 17:42
Yes , of course you can upgrade the call manager 7 from the remote server
Set up the SFTP server on the local machine where you have the upgrade file
On the call manager under the Od administration in install upgrades give the path to the SFTP server
select (/) in the directory and call manager will automatically detect the files which it need to upgrade
Regarding setting up the SFTP server, I will be uploading a document to to set up the SFTP server shortly
Vivek
Chris Deren Sun, 11/29/2009 - 09:07
Read the CM release notes for how to merge the files into a single sgn file and then remote install via sftp will work for you.
HTH,
Chris
