Webvpn CIFS auto login
manfernandez Sun, 11/29/2009 - 15:24
Are you using LDAP authentication with the VPN?  If so, you can use the GROUP POLICY----> Single Sign On
This will use the credentials you used to log into the VPN (assuming you ARE using LDAP)  this should auto log them in without putting in passwords.  Also on the server side, you can still audit the deletes, creations etc.
Let me know if you need the LDAP config piece.
Hope this helps
Manny
manfernandez Sun, 11/29/2009 - 15:25
If you need the LDAP config piece, let me know
Hope this helps
Manny
