Does 3750-12S GigE Port Support 10/100/1000Gbps or just 1000Gbps
Answered Question
Nov 25th, 2009
Just want to confirm is the 3750-12S GigE Port support variable speed or is it fixed 1GigE only.
Bill
Correct Answer by Leo Laohoo about 7 years 1 month ago
Only the GLC-TX will support 10/100/100.  If you want the SFP to support 100mbps (only) then you need to look at the following link:
Cisco 100BASE-FX SFP Fast Ethernet Interface Converter on Gigabit SFP Ports
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6578/product_data_sheet0900aecd801ba88e_ps5000_Products_Data_Sheet.html
The Cisco 100BASE-FX SFP on Gigabit SFP ports is supported on Cisco Catalyst 3750, 3560, and 2970 series switches.
Jon Marshall Wed, 11/25/2009 - 14:15
Bill
Short answer is yes. Have a look at the Q&A for the 3750, the "Technology Overview" section, about 1/3 of the way down -
3750 Q&A
Jon
billsayegh Wed, 11/25/2009 - 15:00
Thanks Jon
I checked the Q&A and it does not specifically state that the 3750-12S supports 10/100/1000.
What I could find is:
WS-C3750G-12S-E
• 12 SFP-based Gigabit Ethernet ports
• 32 Gbps, high-speed stacking bus
• Innovative stacking technology
• 1 RU stackable multilayer switch
• Enterprise-class intelligent services delivered to the network edge
• IP Services Image installed provides full dynamic IP routing
Is the below refering to the 3750-S SFP ports, by stating the SFP port it is implicit that all SFP support 10/100/100?
Can the 1000BASE-T SFP support 10/100/1000 speeds?
A. Yes, the 1000BASE-T SFP can support 10/100/1000 speeds on the Cisco Catalyst 3750 Series Switches. Please refer to the 1000BASET-T SFP Compatibility Matrix for information about support on other Cisco products.
Bill
Correct Answer
Leo Laohoo Wed, 11/25/2009 - 15:15
