CUPC Client "Connected(Limited)" when registering
Michael Murray
Level 2
Level 2
When I start my CUPC client it looks like it registers with the CUPS server but that's it. I get a "Connected(Limited)" status and I can't make any calls. The server health screen (attached) shows that I've downloaded the config (TFTP) ok but I can't connect to the Presence server. It cycles through "Connecting (Primary)" and "Disconnecting (Pending Retry)". The Presence server status screen shows the right server and I can ping the server from the PC by using the server name. I'm not using DNS though. Not sure if it matters but I'm resolving the name by using a local host file.
htluo
Level 9
Level 9
Go to CUPS > System > Security > Incoming ACL.  Add an ACL with the following:
Description: All
Address Pattern: All.
Michael
http://htluo.blogspot.com
5 Replies 5
htluo
Level 9
Level 9
Description: All
Michael
JustForVoice_2
Level 4
Level 4
Hi Michael,
I do not think it is Access list problem. I think there is no Digest credentials under the users in CUCM.
The "ACL" is to bypass the digest credential check.  Otherwise, you'll have to configure digest credential for every CUCM user.  It's not going to be fun without BAT.
Michael
You are the Boss Michael, I thought the default for ACL to allow. Is it deny by default??
One more thing, even if he add the ACL or Digest, the word limited will remain. unless he integrate with LDAP. true or false ?
You're right.  When there's an outstanding item in "show server health", CUPC will show "limited".
Michael
