BGP VPNv4 Peer Table
Nov 25th, 2009
Hey all,
  Is there a way that the BGP VPNv4 peer table can be monitored like the global BGP table (1.3.6.1.2.1.15)
[[email protected] ~]# snmpwalk -v 2c -c snmpro 192.168.255.129 -m all 1.3.6.1.2.1.15
BGP4-MIB::bgpVersion.0 = Hex-STRING: 10
BGP4-MIB::bgpLocalAs.0 = INTEGER: 64750
BGP4-MIB::bgpPeerIdentifier.192.168.255.130 = IpAddress: 192.168.255.130
BGP4-MIB::bgpPeerIdentifier.192.168.255.131 = IpAddress: 192.168.255.131
BGP4-MIB::bgpPeerIdentifier.192.168.255.132 = IpAddress: 192.168.255.132
BGP4-MIB::bgpPeerState.192.168.255.130 = INTEGER: established(6)
BGP4-MIB::bgpPeerState.192.168.255.131 = INTEGER: established(6)
BGP4-MIB::bgpPeerState.192.168.255.132 = INTEGER: established(6)
ROUTER#show ip bgp vpnv4 all summary
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.98.128.222   4 64774      75      77        8    0    0 00:08:08        1
192.168.255.130 4 64750     145     142        8    0    0 02:15:47        0
192.168.255.131 4 64750     139     142        8    0    0 02:15:50        0
192.168.255.132 4 64750     139     142        8    0    0 02:15:43        0
Notice that the 10.98.128.222 peering is not in the global BGP table that SNMP reads?
The closest that I can get is to put a threshold on the amount of prefix recieved via a peering:
CISCO-BGP4-MIB::cbgpPeerAcceptedPrefixes.10.98.128.222.ipv4.vpn = Counter32: 1
CISCO-BGP4-MIB has no table contructs that resemble the ones in BGP4-MIB
Cheers
Adam Clark
clark.adam.p Wed, 11/25/2009 - 23:00
Here you go
ROUTER#show running-config
Building configuration...
*Mar  1 06:04:07.590: %SYS-5-CONFIG_I: Configured from console by console
Current configuration : 6042 bytes
version 12.4
hostname ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip vrf TP_CORE
rd 64750:400
route-target export 64750:400
route-target import 64750:400
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
archive
log config
  hidekeys
interface Loopback0
ip address 192.168.255.130 255.255.255.255
ip ospf 1 area 0
interface Loopback100
no ip address
interface FastEthernet0/0
ip address 192.168.255.3 255.255.255.248
ip ospf 1 area 0
duplex auto
speed auto
mpls ip
interface FastEthernet0/1
ip vrf forwarding TP_CORE
ip address 10.98.128.225 255.255.255.252
duplex auto
speed auto
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
router ospf 1
log-adjacency-changes
router bgp 64750
no synchronization
bgp log-neighbor-changes
neighbor VPNv4PG peer-group
neighbor VPNv4PG remote-as 64750
neighbor VPNv4PG update-source Loopback0
neighbor VPNv4PG send-community both
neighbor 192.168.255.129 peer-group VPNv4PG
neighbor 192.168.255.131 peer-group VPNv4PG
neighbor 192.168.255.132 peer-group VPNv4PG
no auto-summary
address-family vpnv4
  neighbor VPNv4PG send-community extended
  neighbor VPNv4PG next-hop-self
  neighbor 192.168.255.129 activate
  neighbor 192.168.255.131 activate
  neighbor 192.168.255.132 activate
exit-address-family
address-family ipv4 vrf TP_CORE
  neighbor TPPG peer-group
  neighbor TPPG remote-as 64774
  neighbor TPPG send-community both
  neighbor TPPG route-map BGP-VRF-Peers in
  neighbor TPPG route-map TP_CORE_PEER_SECONDARY out
  neighbor 10.98.128.226 peer-group TPPG
  neighbor 10.98.128.226 activate
  no synchronization
exit-address-family
ip forward-protocol nd
ip bgp-community new-format
ip community-list standard AS64750-Local-Pref-300 permit 64750:30
ip community-list standard AS64750-Local-Pref-400 permit 64750:40
ip community-list standard AS64750-Local-Pref-500 permit 64750:50
ip community-list standard AS64750-Local-Pref-200 permit 64750:20
ip http server
no ip http secure-server
ip access-list standard snmp-access
snmp-server community snmpro RO snmp-access
snmp-server trap-source Loopback0
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps vrrp
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps xgcp
snmp-server enable traps flash insertion removal
snmp-server enable traps ds3
snmp-server enable traps envmon
snmp-server enable traps icsudsu
snmp-server enable traps isdn call-information
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps atm subif
snmp-server enable traps bgp
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps cnpd
snmp-server enable traps config-copy
snmp-server enable traps dial
snmp-server enable traps dsp card-status
snmp-server enable traps entity
snmp-server enable traps event-manager
snmp-server enable traps frame-relay
snmp-server enable traps frame-relay subif
snmp-server enable traps hsrp
snmp-server enable traps ipmobile
snmp-server enable traps ipmulticast
snmp-server enable traps mpls ldp
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls vpn
snmp-server enable traps msdp
snmp-server enable traps mvpn
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps pim neighbor-change rp-mapping-change invalid-pim-message
snmp-server enable traps pppoe
snmp-server enable traps cpu threshold
snmp-server enable traps rsvp
snmp-server enable traps rtr
snmp-server enable traps syslog
snmp-server enable traps l2tun session
snmp-server enable traps vsimaster
snmp-server enable traps vtp
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps rf
snmp-server enable traps voice poor-qov
snmp-server enable traps voice fallback
snmp-server enable traps dnis
snmp-server host 10.17.10.20 snmpro
route-map TP_CORE_PEER_SECONDARY permit 10
set metric 200
route-map BGP-VRF-Peers permit 10
match community AS64750-Local-Pref-200
continue
set local-preference 200
route-map BGP-VRF-Peers permit 20
match community AS64750-Local-Pref-300
continue
set local-preference 300
route-map BGP-VRF-Peers permit 30
match community AS64750-Local-Pref-400
continue
set local-preference 400
route-map BGP-VRF-Peers permit 40
match community AS64750-Local-Pref-500
continue
set local-preference 500
route-map BGP-VRF-Peers permit 65535
mpls ldp router-id Loopback0
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line vty 0 4
login
end
ROUTER#show version
Cisco IOS Software, 3700 Software (C3725-ADVIPSERVICESK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sun 09-Nov-08 01:12 by prod_rel_team
ROM: ROMMON Emulation Microcode
ROM: 3700 Software (C3725-ADVIPSERVICESK9-M), Version 12.4(23), RELEASE SOFTWARE (fc1)
ANZDCMWPER2 uptime is 6 hours, 4 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19
System image file is "tftp://255.255.255.255/unknown"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 3725 (R7000) processor (revision 0.1) with 249856K/12288K bytes of memory.
Processor board ID XXXXXXXXXXX
R7000 CPU at 240MHz, Implementation 39, Rev 2.1, 256KB L2, 512KB L3 Cache
4 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity enabled.
55K bytes of NVRAM.
Joe Clarke Thu, 11/26/2009 - 00:10
You need an image with the fix for CSCso90107.  The fix for this bug implemented BGP VPNv4 peer support in the BGP4-MIB and CISCO-BGP4-MIB.  To get such an image, you would need to move to 12.4(15)T9 or higher for your platform.
