How to configure 2 LDAP servers on NAC ADSSO?
Nov 25th, 2009
Hi All,
     How can I input 2 LDAP servers at the User Management > Auth Servers >Lookup Servers > Server URL field.  For example my 2 LDAP servers are 10.10.10.1 and 10.10.10.2.  Should I put it like ldap://10.10.10.1:3268;10.10.10.2:3268 or how?  Thanks.
Dan
Faisal Sehbai Thu, 11/26/2009 - 11:58
  • Gold, 750 points or more
Dan,
It's either a space or a comma, but yes, you would put both of those in the same space but make sure they're both in URL format, i.e ldap://1.1.1.1:3268 ldap://2.2.2.2:3268
Try with a space and a comma to see which one works.
HTH,
Faisal
