Memory for crash kernel message seen during NAC 4.7.0 CD install
Nov 26th, 2009
Dear Sir ,
I want upgrade NAC 4.7.1 from 4.7.0 , but can't running when boot from CD , then I check the error message from CCO and it is a bug.
CSCta19323
No
Memory for crash kernel message seen during 4.7.0 CD install
The message is benign, it is displayed when memory is not configured/allocated for a crash kernel to aid in crash dump. This is displayed by Red Hat and CentOS 5 releases while booting on any system.
How do I fix it ? have any workround ?
thanks
Faisal Sehbai Thu, 11/26/2009 - 11:55
  • Gold, 750 points or more
Read the bug notes. This message is benign, meaning that it doesn't cause any harm. It gets displayed because it's expecting certain version of a software that isn't there.
Your upgrade process should not be hampered because of this bug. If you're upgrading a 3350, make sure you're using keyboard/monitor to do it and not through serial!
HTH,
Faisal
