Which IOS on Cisco 3725 with CUCM 7
I want to upgrade my CUCM from version 4.3 to version 7.0. I have on a remote site a Cisco 3725 with the SRST feature.
I want to know first if this platform is compatible with CUCM and with which IOS ?
Because I've search on the compatibility tools and matrix on Cisco Site, but I haven't find any reference for this platform.
It's specified that we need to put at minimum an IOS release 12.4.20 T on the Voice Gateway, but the last version for 3725 is 12.4.15 T11
Thanks in advance for your response if someone has encountered this case
Baptiste
Hi Baptiste,
Check if the attached document helps you.
-> Sushil
vivkalra
Here is the IOS compatility matrix with the Call Manager which clearly mentions which IOS is
compatible with which CUCM specific to Model of router
Also the link to the Hardware compatibilty :-
vivkalra
Here is the link to the IOS compatibility matrix which clearly mentions the IOS compatibility to the CUCM
with respect to the model of the gateway
http://www.cisco.com/en/US/docs/voice_ip_comm/uc_system/unified/communications/system/versions/IPTMtrix.html
