Crypto key generate
Nov 26th, 2009
the ssh service on the supervisor engine is unavailable after each reboot, which is painful. Hence we need to re-generate an SSH key after each reboot using 'crypto key generate rsa'
Version: "bootflash:c6msfc3-pk9sv-mz.122-14.SX2.bin"
best regarsd
glen.grant Thu, 11/26/2009 - 07:07
   Don't know what would cause that . The keys should not be wiped out and rebooting should not disrupt the SSH functionality as the keys are stored in NVRAM .  Done literally a 1000 boxes with SSH and never seen this issue.  You could look for a bug in your version  but have never seen or heard of anything like that.  I would verify your SSH config is correct and if it continues get ahold of the TAC , they might want to replace the supervisor .
hamsofiane Thu, 11/26/2009 - 11:14
Thank you for your response, i would like confirme you that i have tested with vesion sup-bootdisk:s3223-ipservicesk9_wan-mz.122-18.SXF16.bin"
and i do not have the problème after the reload , I can see that my key still in the NVRAM.
THe configuration is :
line con 0
line vty 0 4
access-class vty-acl in
login local
transport input ssh
I do not know if the problème is in the software version or not ? I will test with this version
In the documention i see that we can storge the key :
[general-keys | usage-keys | signature | encryption] [label key-label] [exportable] [modulus modulus-size] [storage devicename:] [on devicename:]
could give us a correct commande permit that ?
Best regards
