ASA 5550 ACl's
Nov 26th, 2009
I am carrying out some cleanup tasks on our 5550 firewall; and am using the syntax below in conf t to remove old access-lists (the majority are access lists left from captures etc) :
host# sh access-list CAP1
access-list SL-CAP; 0 elements
host# conf t
host(config)# clear configure access-list CAP1
host(config)# wr
Building configuration...
[OK]
host(config)# end
access-list CAP1; 0 elements
All other access lists apart from this and one other have removed as expected - I have checked to see if the captures are still running, but they have been removed.
Any advice that you could be provide would be greatly appreciated, thankyou in advance!
Tanveer Deewan Thu, 11/26/2009 - 16:37
can you get the output of the following?
show run | i CAP1
show run | i SL-CAP
Dale Sanderson Fri, 11/27/2009 - 01:14
Forgive my mistake - there is only one access list I am in reference to -  that was my mistake on failing to sanatise the output properly
In full :
host# sh access-list SL-CAP
host# conf t
host(config)# clear configure access-list SL-CAP
host(config)# wr
[OK]
host(config)# end
host# sh run | inc SL-CAP
#no output#
Related Content
