ASA5500 AAA SERVER GROUP (RADIUS) -> FREERADIUS AUTH
Nov 26th, 2009
hello,
i'm trying to authenticate users from ASA 5520 to FREERADIUS on Debian
Does anyone succed in ? what's the way to ?
thanks
Ivan Martinon Wed, 12/02/2009 - 10:08
  • Cisco Employee,
Did that once and worked like a charm, as far as I remember you need to manually edit the clients.conf file on the radius service of freeradius and add the NAS ip address, key and ID I believe the doc for freeradius will help:
http://wiki.freeradius.org/Configuration
cheers
vpancisco Thu, 12/03/2009 - 00:40
thanks
ok it found now !!
but only if i put in clear text the password in the users file as:
youruser   Cleartext-Password := "somepass"
           Service-Type = NAS-Prompt-User,
so i don't use password stored in the freeradius data base
that's not enough secure for an auth service
regards
Conor Cunningham Sun, 12/06/2009 - 11:40
There are many other databases you can use. Check the users file in /etc/raddb/users for examples.
You can also have it authenticate against the unix user db, i.e. /etc/passwd. This is the default configuration for freeradius.
e.g. /etc/raddb/users
DEFAULT Auth-Type = System
        Fall-Through = 1
/etc/passwd uses MD5 for its hashing if I'm not mistaken.
Cheers,
Conor
