PBX FXO LINE WITH "OUT OF SERVICE"
Nov 26th, 2009
HELLOU I AM GETTING OCASSIONALY APROX EVERY WEEK A PBX LINE THAT SAY FROM EXTERNAL CALLS TAHT THE LINE IS "IN REPAIR OR OUT OF SERVICE" AND THE ONLY WAY TO SOLVE IT IS RESTARTING THE SYSTEM. ANY HELP WILL BE APPRECIATED. THANKS
Marcos Hernandez Fri, 12/11/2009 - 06:41
We will need more information in order to help you. Is this a UC500? Are you using FXO ports? Have you checked the wiring?
Marcos
ciscomorales Mon, 12/14/2009 - 15:10
Marcos. This is an UC520W-8U-9K system. but for other reasons soon i am going to change to Key system config instead to PBX. Can you tell me an easy way of migrate from PBX to Key System?, as a upgrade guide, do i need to backup which files in case, etc. I will appreciate all the info can you provide me. thanks in advance. Carlos
Related Content
