Problem with EVENT
Answered Question
Nov 26th, 2009
Hi everybody.
Early - i use
event manager applet APPLET1
event track 1 state any
action ACTION1 cli command "enable"
action ACTION4 cli command "clear ip nat translation *"
To clear nat translation when one link to ISP fall and i reconnect to another
But now  in 12.4(19b) - ADVSECURITY - i can use *event track 1 state any* - becose IOS doesn't know this.
What can i do? Maybe somebody knew?
Correct Answer by Joe Clarke about 7 years 6 months ago
Enhanced Object Tracking support was not added to EEM until 12.4(2)T.  In the meantime, you can use the syslog ED to do what you want.  For example:
event manager applet track-down
event syslog pattern "TRACKING-5-STATE: 1.*Up->Down"
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation *"
If the syslog message is not available, then you can use SNMP and the CISCO-RTTMON-MIB.  Here is an example:
https://supportforums.cisco.com/docs/DOC-8069
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sat, 11/28/2009 - 22:13
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
