"Body-Contains" limit
Nov 26th, 2009
I can't find this documented anywhere, but I am thinking there is a maximum number associated with the number of matches that can be counted with the 'body-contains' rule, for example;
body-contains("someword",1000) - works just fine
...but using say a count of 10,000 (a lot, I know!) does not.
[EDIT : I figured this out, 10,000 works fine! Apologies for the hasty post]
<Snip>
Thanks guys!
Chris.
Andrew Wurster Thu, 11/26/2009 - 17:42
i can't find it documented anywhere. but it sounds like a bad idea... content filters (GUI) have form validation to restrict you from entering a value of > 1000 term matches. message filters (CLI) may lack similar data validation but it uses more or less the same scanning capabilities so there must be a resource consumption type reason to limit term matches to 1000. i've only ever seen someone use values from 1 through 10 in that field to be honest.
if you do decide to use that in production - let us know what happens.
andrew
