Anyconnet client fails to connect
Nov 26th, 2009
Hi all,
Having installed AnyConnect client 2.4.0.202 on an ASA5520 running 8.2.1.
The AnyConnect installs fine gets its profiles from the ASA.
In the profile, Ive configured the ASA hostname and IP address as shown below :
    <ServerList>
        <HostEntry>
            <HostName>vpn.company.net</HostName>
            <HostAddress>ip_address_of_ASA</HostAddress>
                If present, UserGroup will be used in conjunction with
                HostAddress to form a Group based URL.
                NOTE: Group based URL support requires ASA version 8.0.3 or
                      later.
            <UserGroup>Company_group</UserGroup>
        </HostEntry>
    </ServerList>
The problem is that even though I can resolve vpn.company.net to the right IP address of the ASA, the
AnyConnect client reports "Invalid host entry, please re-enter".
IF I instead type in the IP address of the ASA, it works.
I would like to have it working with the hostname, as the certificate matches the hostname.
Any help appriciated
/KD
Yudong Wu Thu, 11/26/2009 - 12:20
  • Gold, 750 points or more
If you don't configure a "group-url" on ASA, remote " Company_group" and try again. is not "tunnel-group" on ASA.
kelvindam Fri, 11/27/2009 - 01:12
Hi Kevin,
Thx for the input - but unfortunately that didnt help.
The AnyConnect client still reports the same error upon start from the start menu.
(Starting from a browser it works fine).
Any other ideas? :)
KD
