Question about 3750 stack SVI mac-address
Nov 26th, 2009
I have a question about 3750 stack. If master stack fail, new master will take old master, then SVI mac-address will be change.
3750 any command make SVI mac-address will not change?
rupam_chakra1983 Thu, 11/26/2009 - 23:29
I hope the persistence MAC address feature will help you out.
but you can use the " Persistense MAC address " faeture .
if you enable this then if the master goes down then by default it will keep the old mac address for 4 minutes by default.
and after the expiration of the time the MAC address will be replaced by the new stack master MAC address.
But  if you enter the command with a "0" value parameter in that case the MAC address will be there until you enter the no command.
The command is
stack-mac persistent timer 0
Note: beware of the consecuences in the production network
Plz rate it if found useful
chungmaster111 Thu, 11/26/2009 - 23:36
thank you for your relpy.
STACK MAC Persistent Timer 0 this command do impact of network (such as STP, etherchannel, routing.....) ?
rupam_chakra1983 Fri, 11/27/2009 - 02:09
it will not create a problem in normal case.
But if you are using the old master switch whose MAC address is binded in the stack in the same network.
there may be a chance of duplicate MAC address and network outage.
So to avoid this don't plug the removed master switch in the network.
plz rate this if you found it useful.
