How do I fix Missed Call/Received Call numbers so that you can dial them from the menu correctly
Nov 27th, 2009
Hello all,
I have some problem when i receive call the caller ID information are like this 123456678 and i can't dial this directly, i wan t to know how i can modify the caller ID to be display correctly to my IP phone like this 0123456678 or 00123456678 to direct dial
i'm not sure if its the best way, but i find the easiest way to add a translation-rule that add's the leading 0 onto the calling number.
voice translation-profile IncomingProfile
translate calling 50
voice translation-rule 50
rule 1 // /0/
This displays in your missed/received call with the extra 0 allowing you to return the call
Stephen
