Monitoring DSP resources, SNMP OID
Nov 27th, 2009
Hi again, cisco gurus!
Have been looking for SNMP OID that allows to monitor the number of DSP-channels active on Cisco router for some days.
Has someone investigated this task? completely perplexed
thanks,
Boris Borodin
chris.mann Tue, 12/01/2009 - 04:07
Check out this link
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_dsp_notifications.html#wp1054016
Also some additional information --
  • dspu—Sends a notification whenever the operational state of the physical unit (PU) or the logical unit (LU) changes or activation failure is detected. This is from the CISCO-DSPU-MIB, and the notifications are:
    enterprise 1.3.6.1.4.1.9.9.24.1.4.4
    1newdspuPuStateChangeTrap
    2 newdspuPuActivationFailureTrap
    enterprise 1.3.6.1.4.1.9.9.24.1.5.3
    1 newdspuLuStateChangeTrap
    2 dspuLuActivationFailureTrap
  • dsp—Sends a notification whenever the DSP card goes up or down. This is from the CISCO-DSP-MGMT-MIB, and the notification is:
    enterprise 1.3.6.1.4.1.9.9.86.2
    1 cdspMIBCardStateNotification
  • Also you could check out these two MIBS, from website http://www.cisco.com/go/mibs
    CISCO-DSP-MGMT-MIB
    CISCO-DSP-MGMT-CAPABILITY-MIB
    Hope that helps,
    CM
    Medved_RC Mon, 06/21/2010 - 00:48
    Hi! I have similar question.
       I have 2811 that uses like onramp/oframp fax-server.
        I need to monitor number of faxes that DSP is operates in time. I want make some graphs (in cacti or MRTG) that show load dsp
        resources by faxe's for optimizing number of DSP card in router and monitoring  max fax load time.
        I search in MIB but couldn't find strict that i want.
        May be you have some solution for such kind of question.
    Tank you.
    Alejandro Rodriguez Thu, 04/14/2011 - 12:09
    Medvec_Rc
    I have the some problem? Can you resolved it?
    I have 2811 that uses like fax onramp, and need the number of fax is received at time.
    Who can helpme.
