ACS View 5 Remote Database
Nov 27th, 2009
The online help and PDF doc seem a little vague about the remote database feature....I'm wondering whether it will write the entire View database every time or just the new data?
I notice the scheduled jobs is called Export which sounds like it might do the entire db. But, since you can go right down to 1hr intervals it would seem more logical for only new records to be exported - espcially if the database is large.
Thx
