Understand output from "show ip mroute" - Help
Nov 27th, 2009
This is quite basic, can some one please explain what the output below shows. Why do I see NULL in outgoing and incoming? Is there a problem here?
sh ip mroute 239.48.181.10
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
       L - Local, P - Pruned, R - RP-bit set, F - Register flag,
       T - SPT-bit set, J - Join SPT, M - MSDP created entry,
       X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
       U - URD, I - Received Source Specific Host Report, Z - Multicast Tunnel
       Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.48.181.10), 3w3d/stopped, RP 10.239.45.1, flags: SP
  Incoming interface: Null, RPF nbr 0.0.0.0
  Outgoing interface list: Null
(10.44.80.31, 239.48.181.10), 00:00:07/00:02:52, flags: P
  Incoming interface: GigabitEthernet1/4, RPF nbr 10.10.51.145, Partial-SC
(10.45.180.38, 239.48.181.10), 1w0d/00:02:59, flags: PT
  Incoming interface: Vlan180, RPF nbr 0.0.0.0, RPF-MFD
show ip mroute count:
Group: 239.48.181.10, Source count: 4, Packets forwarded: 0, Packets received: 31325457
  RP-tree: Forwarding: 0/0/0/0, Other: 0/0/0
  Source: 10.44.80.31/32, Forwarding: 0/0/0/0, Other: 18/18/0
  Source: 10.45.180.38/32, Forwarding: 0/-229/0/281, Other: 31325425/0/31325425
Thanks in advance
Dan
vdadlaney Fri, 11/27/2009 - 08:09
Thanks in advance
Dan
Hi Dan,
Is this output taken from the RP itself. If so than that is probably the reason why the Incoming interface is null on the *,G entry. The reason the S,G entry might be null is probably because you do not have any receivers that are requesting the traffic.
Disclaimer: I am definetly no multicast expert hence I apologize if this might be incorrect and would appreciate if some of the experts on the forum could confirm this as well.
Thx
dan_track Fri, 11/27/2009 - 08:13
This was done on the RP itself. Can someone please clarify this.
Dan
Giuseppe Larosa Fri, 11/27/2009 - 09:36
  • Hall of Fame,
    Founding Member
Hello Dan,
until the code P is part of the state of the mroute it is correct to see outgoing interface = null.
>> end of show
according to the point of view of this device no one in other IP subnets has showed interest in receiving traffic for group 239.48.181.10.
However, there are two sources in two different subnets sending traffic using this group address.
Traffic is dropped that means it is not routed to other IP subnets.
if a PC joins the group the node should start to route for the group
Hope to help
Giuseppe
Pradeep H A Sun, 11/11/2012 - 21:06
Hi Giuseppe,
It would be great if you can advise what the word "stopped" in the first entry mean & why the RPF neighbor is 0.0.0.0 in the last entry?
Thanks a lot
Pradeep H A
john smith Sun, 01/20/2013 - 09:43
i have the same issue is there any solution for the this?
HAL-HPSDC01-B01-CSW01#sh ip mroute 239.1.1.1
       T - SPT-bit set, J - Join SPT, M - MSDP created entry, E - Extranet,
       Z - Multicast Tunnel, z - MDT-data group sender,
       V - RD & Vector, v - Vector
(*, 239.1.1.1), 02:21:00/stopped, RP 10.10.10.1, flags: SP
(10.23.1.250, 239.1.1.1), 02:21:00/00:02:06, flags: PT
  Incoming interface: Vlan301, RPF nbr 0.0.0.0
thanks
Quang Do Xuan Thu, 10/03/2013 - 23:04
It's NULL because route through RP was pruned due to SPT switchover from shared stree. That happens after first few packets then source starts sending packets to receivers via their own SPT, that makes the SPT via RP unnecessary then it is pruned (marked as P)
Related Content
